Spec editor - Allow multiple selection
When creating a new entry in the spec, say a reducer, I want to reduce the number of size entries that are listed.  It's very cumbersome to click in the small  checkbox many times.  For example, in the reducer case, there are about 200 sizes listed.  I only wanted one or two in my spec.  Clicking on 198 little check boxes got really old.  A multitple selection using a range would be very helpful.
3 Comments
lfitzhenry
It is possible to filter the sizes when adding the reducers to the catalog. Use the "Size Range" and "Reducing Size Range" filter before adding the part to your spec. This will automatically check and un-check the boxes that you want.
jeremy.teague
Observer
I understand your pain. I second the motion to add this feature.
In particular the multi-select functionality would be helpful in the  "Edit Parts/ Part List/ Remove from Spec" boxes.
http://help.autodesk.com/view//PLNT3D/2018/ENU/index.html?guid=GUID-BEB9C8D7-20C7-41B2-B58A-428C93A3...
Vicky.Wu
