PLANT 3D SPECS - LONG DESCRIPTION FORMULA - NEED ADDITIONAL PROPERTY FIELDS
There are several other property fields shown in the Plant 3D Specification export to Excel  (Such As End_Type_S2, Schedule_S2, ETC...).  It would be very helpful to have these other properties available as Property Names in the Long Description Formula.
In particular, we need a way to add Port 2, Port 3, and Port 4 information to the Long Description Formulas.  We regularly encounter piping components that have one end socket weld and the other end threaded.  With only one option for End Type, we are currently using an empty field to manually add this important information (e.g. SW x THDF).
2 Comments
ZZikic
Also would be nice to have more columns to filter on in the Common Filters section of Spec Editor, such as:
Flange Std
Gasket Std
Compatible Standard
Item Code
Wall Thickness
With these it will be much easier to assign Long Description Styles to spec components.
”Boost
