Plant 3d and Revit integration, via ifc files and BIM360
(Versão em português abaixo)
I need to use the BIM methodology to integrate Autocad Plant 3D and Revit. I believe the best way is to use .ifc files. How to make Plant 3d export files that are read with BIM information by Revit? It is necessary to implement a way to make Plant 3d and Revit talk to each other, with effective integration by BIM 360, as already existed between Advance Steel and Revit, via arguments .ifc
Preciso utilizar a metodologia BIM para integrar Autocad Plant 3D e Revit. Acredito que a melhor forma é usar arquivos .ifc. Como fazer o Plant 3d exportar arquivos que sejam lidos com informações BIM pelo Revit? É preciso implementar uma forma de fazer Plant 3d e Revit conversarem entre si, com integração efetiva pelo BIM 360, como já exite entre Advance Steel e Revit, via arguivos .ifc
1 Comment
rbarbosa8DQGJ
Plant3d and Revit does not interoperate in a good level. There is no way to export to IFC file between those two softwares, so I created this idea:
There is a way to use PCF file format to export/import from and to Revit. Is not that easy but maybe will help you.
https://blogs.autodesk.com/revit/2017/07/26/exporting-pcf-files-from-revit/#comments-section
https://blogs.autodesk.com/revit/2017/07/27/exporting-pcf-files-from-revit-2018-part-2-assemblies/
I also posted an Idea to make this PCF export/import more easy.
https://forums.autodesk.com/t5/revit-ideas/make-isometric-piping-more-easy-with-pcf-file-export/idi-...
Vote for it.
