While we are waiting in wain for Autodesk to make it possible to map and transfer properties between Plant 3D P&ID and Forme - Define a workaround to transfer the attributes and properties in connection to the revision control.
It gives good meaning to increase the Forma database to be reliable to handle the revision data it is supposed to handle. Any new API programming architecture with alternative parallel use of support databases is most welcome.
