AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Swagelok Tubing Spec
6 REPLIES 6
hardingster
9131 Views, 6 Replies
I am looking for a spec or catalog suitable for using in place of a swagelok tubing (SS Tubing) spec for instrumentation lines in Plant3D 2013. I cannot find a tubing spec in the Plant Exchange content packs.
Any help would be really appreciated.
6 REPLIES 6
I have a lot Swagelok fittings and ASME BPE tubes but I made them up myself. There are ASME BPE officially released catalogue, but it was not good enough to me.
Attila Vallyon
chad70811
in reply to: Attila.Vallyon
Attila,
Did you actually put together a custom catalog and generate your own specs from it? I am also looking for a spec or catalog for swagelok, the ASME BPE was not sufficient for our needs either.
Thanks, Chad
hardingster
in reply to: chad70811
I have not been able to make a spec, I am currently using a butt welded spec for reference with no fittings. I will need to create one soon but I was hoping there was a good Samaritan out there and would give me a start.
Attila.Vallyon
No.
I used the ASME pipes and fittings, and the ASME valves catalogues as bases. But almost all elements are imported Autocad geometry (especially the valves) so I could have set up a new catalogue as well.
Attila Vallyon
cuiken
in reply to: hardingster
Where can I get a Swagelok-Tubing catalog?
schusterAPRO
You may have a look here .
Stay tuned!
Steffen
”Boost
