I figured out how to modify the look of the skew triangle by adjusting the settings in the "Skew" section of the isoconfig.xml file, but one thing I can't find the setting on is how to adjust the distance between the end of the triangle and the piping component? For me the distance is too great.
Hello Eric,
If I am understanding you correctly, I believe you may want to check for the following in the isoconfig.xml:
<!-- 'MinLeaderLength': (double); Minimum distance between annotation & component beyond which a leader would be drawn. -->
<!-- 'BumperDistance': (double); Mininumum spacing between an annotation and any other entity in the model. -->
I hope this helps!
Hello Eric,
I haven't heard back to you about this forum issue, if the information I posted has helped please mark it as "accept solution". Please let me know if you have any further questions or if you need any more assistance.
Sorry, we just started our refinery turn-around today and I've been fairly busy. Neither of those sections changed the gap distance of the skew triangle and the piping.
I appreciate any advice you can provide.
