AutoCAD Plant 3D Forum
Ortho Creation Problems after Kubit installation
2 REPLIES 2
EricNyh
514 Views, 2 Replies
Has anyone had any issues with creating or editing ortho viewports after Kubit PointSense Plant has been installed?  I didn't notice it at first since I was working a new project, it was actually noticed on another machine where they were finishing up a project.
If you go to edit an existing ortho viewport, the shading will switch to 2D wireframe and the view will zoom to 0,0 very tightly.  So if you swap back to Realistic mode and zoom extents, you'll see the model where you can find the view cube.
Another thing is that right after you click the viewport to edit, it'll say in the command line that the orthotemp.dwt (not sure about the name) is missing, yet it is there.
I will also get a Autocad crash dialog when I close Autocad.
2 REPLIES 2
It may be worth checking by uninstalling the PointSense software, reboot the computer, and see if you get the same behavior in Plant 3D. It may not have anything to do with Kubit(?) So that may help determine if it’s the PointSense add-in or not.
You may need to contact Kubit directly for a support solution.
And you may want to consider trying out ReCap for your point cloud work.
If my reply post was helpful, please give a "Kudos" or mark the "Accept as Solution" button below (or both).
Martin Stewart
AEC Support Specialist
Funny, I just received a fix from Kubit.  It appears Kubit changes the default template folder location.  Once I fixed that, ortho started working again.
”Boost
