AutoCAD Plant 3D Forum
Back to Back placement of a weldolet causes error in Iso production
4 REPLIES 4
bora.kocaman1980
418 Views, 4 Replies
I placed two weldolets at the same point on a pipe but 180 degrees apart. The purpose is to make a cross from a pipe. In iso production this caused an error. I got the classical error message "FAILURE - Object reference not set to an instance of an object."
Any solutions for this?
4 REPLIES 4
jabowabo
in reply to: bora.kocaman1980
Move one of them a very small distance. This is the only workaround I have found.
EricNyh
in reply to: jabowabo
I had a support ticket on this a while back, for version 2014.  Like jabowabo says, if you move one like .001" away from the other, it works.
PeterQuinn
in reply to: EricNyh
I am pretty sure we fixed this in one of the previous versions. I tried it in 2016 and it works fine.
Peter Quinn
Senior Product Manager
Autodesk, Inc.
Thank you all guys. I tried moving but it did not work but I think I have found the solution. Weldolet creates a red dot in the middle of the pipe. I realized that I accidentally got that dot in another line number and the olet itself to another. When this happens it gives an error. I included all the components of olet to the same number it worked.
”Boost
