自作したカタログの自由なサイズ調整
tst3dcad-kk
自作したカタログの自由なサイズ調整
tst3dcad-kk
自作した3Dソリッドを機器やバルブとしてカタログに導入したいのですが、15A、32A、65Aなど様々なサイズに対応できるように呼び径や大きさなどを自由に変更できるようにしたいです。
Excelを使用した方法など、何か方法がありましたら教えていただきたいです。
h_eger
Dear @tst3dcad-kk ,
your Japanese has landed you in the English Plant 3D forum.
If you want to continue writing in Japanese, please continue on this forum.
Otherwise, please communicate in English here, as my Japanese is very rudimentary.
https://forums.autodesk.com/t5/ri-ben-yu/ct-p/511
as for your question of course this could be changed but I think the effort to adjust the complete Plant 3D system from project setup to pipe specs and catalogs is a lot of work.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
tst3dcad-kk
Thank you. I would like to see an example of how to do this.
Michiel.Valcke
If I understand correctly you want to be able to create python scripts so you can use your new parametric geometry to create multiple catalog parts each with different sizes ...
See the links in this article for more information and some guidelines to put you on your way.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-script-comp...
tst3dcad-kk
丁寧な回答ありがとうございました。
