Good morning,
i have various clamp sizes in my project and the nominal size appears wrong on the isometrics. For example the size NW 15 appears aswell on the isometric drawing as in the BOM as NW 20.
Thanks for your help!
Gab
Hi @medvegab,
Not very easy, please upload the PCF file from your Iso.
There may be many possibilities from the catalog to PipeSpec or an error in the drawing.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Hi @h_eger,
thanks for your fast reply. I know that is not very easy. I've tried a lot of things, but haven't found a right setup.
I think it is going on the size parameters of the clamps. The size NW 15 and NW 20 have the same dimensions in the spec editor.
I have created a line with various clamp sizes, but i can't upload the pcf file. 😞
I have the same problem in Plant3D 2017, the clamp has the wrong size in the PCF file and it only happens with 3/4"and 1" sizes. I have attached screen shots of the iso's and the pcf file for the 1" pipe is below
ISOGEN-FILES ISOCONFIG.FLS
UNITS-BORE INCH
UNITS-CO-ORDS MM
UNITS-WEIGHT KGS
UNITS-BOLT-DIA INCH
UNITS-BOLT-LENGTH MM
PIPELINE-REFERENCE UserDefinedLine
DATE-DMY 06 JUL 17
ATTRIBUTE1 015-158
PROJECT-IDENTIFIER 015-158
REVISION 0
END-POSITION-NULL
CO-ORDS 6122.7596 4322.5674 0.0000
END-POSITION-NULL
CO-ORDS 6213.2471 4322.5674 0.0000
COUPLING
END-POINT 6167.2096 4322.5674 0.0000 1.0000 TC
END-POINT 6122.7596 4322.5674 0.0000 1.0000 PL
SKEY FEFA
ITEM-CODE test-7
ITEM-DESCRIPTION DT-4.1.4-1 A, FERRULE
FABRICATION-ITEM
PIPING-SPEC test
TRACING-SPEC
COMPONENT-ATTRIBUTE1 SERVICE_NA
COMPONENT-ATTRIBUTE2 BOMCOLUMN_Material_
COMPONENT-ATTRIBUTE3 BOMCOLUMN_Spec_test
COMPONENT-ATTRIBUTE4 BOMCOLUMN_LoopNumber_
COMPONENT-ATTRIBUTE5 BOMCOLUMN_Type_
COMPONENT-ATTRIBUTE6 BOMCOLUMN_ISOTag_
COMPONENT-ATTRIBUTE7 BOMCOLUMN_SCHClass_
CLAMP
END-POINT 6167.2096 4322.5674 0.0000 1.5000 Universal_ET
SKEY CLMP
ITEM-CODE test-1030
ITEM-DESCRIPTION TRI CLAMP
ERECTION-ITEM
PIPING-SPEC test
TRACING-SPEC
GASKET
END-POINT 6168.7971 4322.5674 0.0000 1.0000
ITEM-CODE test-666
ITEM-DESCRIPTION GASKET - Generic
ERECTION-ITEM
PIPING-SPEC test
TRACING-SPEC
COMPONENT-ATTRIBUTE7 BOMCOLUMN_SCHClass_150
WEIGHT 0.0045359702440352
COUPLING
END-POINT 6168.7971 4322.5674 0.0000 1.0000 TC
END-POINT 6213.2471 4322.5674 0.0000 1.0000 PL
SKEY FEFA
ITEM-CODE test-7
FABRICATION-ITEM
PIPING-SPEC test
TRACING-SPEC
MATERIALS
ITEM-CODE test-1030
Schedule
PressureClass
Material
Spec test
LoopNumber
Type
ISOTag
ITEM-CODE test-666
Schedule
PressureClass 150
Material
Spec test
LoopNumber
Type
ISOTag
ITEM-CODE test-7
Schedule
PressureClass
Material
Spec test
LoopNumber
Type
ISOTag
Hi .. I have the same issue running Plant 2018.1.2 update. Seems that Autodesk still can not figure this out - or the answer is to be found in another thread.
Okay - figured out we have two Clamps in the same Pipe Spec - and some how the catalog seems to be confused over the sizes - specially when Long Description Size are the same..
To solve it quickly in 3D model, choose the clamp itself - by holding the CTRL button in keyboard and then click on the clamp.
Now you can choose between more clamps - choose the right one - and now you should have the right size in the BOM list in the isometric.
I'm reporting same behavior in Plant3D 2023.
My solution:
Add into the iso.atr next atrribute:
BOM-ATTRIBUTES
EngineeringItems.Size
Find in the isoconfig.xml in tablescheme BOM next row:
<ColumnMapping HeaderName="Size" HeaderRefName="Size" Label="ND" />
replace by
<ColumnMapping HeaderName="Size" HeaderRefName="EngineeringItems.Size" Label="ND" />
It works for me.
Bye
Tomas
