AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Want to reduce the counts of isometric drawings
2 REPLIES 2
300 Views, 2 Replies
Hi I have problem on generate isometric on Autodesk plant 3d 2018. I want the program only create one drawing for this line, however, it creates 18 isometric drawings and it split after each component, like bend, reducer, grayloc connection and flange. see attached file.
I have checked all componets on on the same line number tag and the total length of the pipe is not more than 5m. And I have tried different method like:
1) adjust the congestion splitting to max
2)using start and break point
3)edit the isoconfig.xml for splitoptimization and delete weld and weld field on splitpoint filer under defaultsplitpoints.
But nothing work, please help.
2 REPLIES 2
TomislavGolubovic
Check that the welds have the same line number as the line you're running also
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
in reply to: TomislavGolubovic
Hi Tomislav Golubovic,
I have tried to use add to selection, connected path between parts and connected all lines. But it seems still not working. It breaks under the weld point.
Technology Administrators
AutoCAD Beta
