Visual control commands lock into pan command
mmxxxl
mmxxxl
Good day all!
I'm an currently using plant 3D 2016 updated with sp2 and have a perpetual problem with the computer locking up in the pan command after a few minutes of use causing me to exit and restart the program, again and again at least 30 times in a normal day or it completely locks up and the program crashes (I have also filled out well over 50 of the crash reports for whatever good they do.) I am currently running the system on a dell precision t1700 with windows 10 pro, 64 bit operating system, 16 GB of installed memory, NVIDIA Quadro K2200 video card with the latest update, and I am operating it as a client from a main server. After 3 mins of use in moving around the drawing and selecting orbit, zoom, or pan the system eventually locks into pan no matter which other visual manipulation commands I select. This has been and ongoing problem for over a year now and I have followed the Acad specialist's recommendations in reducing file size, purging the PnP local data cache before start-up, and splitting the drawing into xref's to minimize file size. I have uninstalled and reinstalled many times and have updated the program and components to the most recent service packs and software updates and nothing has worked. I have checked the drawn models on other systems on the server and I don't experience the same issues that I have had on my system. After trying everything that has been suggested by the AutoCAD specialist, every software update, and component upgrade I am still at a complete loss. Anything anyone can suggest to end this nightmare would be greatly appreciated.
dgorsman
What visual style are you using?
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
