Vault and Plant 3D - Drawing Numbering Schemes
max.munkWYZT2
max.munkWYZT2
Hi all,
We are investigating the setup of VAULT for controlling our Plant 3D setup.
I don’t have a setup that i can test on yet - but since we are going to work in a multi discipline environment I’m wondering how tight the integration is between VAULT and Plant 3D.
Can we make the drawing number come from VAULT to ensure a unique number scheme across all applications?
We expect to use a sequential number.
BR Max
johannes.bauer
Autodesk Support
Autodesk Support
Hi Max and welcome to the forums.
There is an integration for Plant and Vault, correct.
But the Plant Project is the administered via Vault and not locally, so more people can work with it.
Drawing number schemes are not supported.
But perhaps this is helping you: https://knowledge.autodesk.com/akn-aknsite-article-attachments/a5811c08-fd5f-484c-b968-9abe2847f6de....
Also there are more resources availalbe for the integration:
https://knowledge.autodesk.com/support/autocad-plant-3d/learn-explore/caas/CloudHelp/cloudhelp/2019/...
AU Class on whats possible:
https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/sfdcarticles/sfdcarticles/U...
Reference card:
https://knowledge.autodesk.com/support/autocad-plant-3d/getting-started/caas/simplecontent/content/a...
Does this help?
HTH
-Johannes
Customer Technical Success
