AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Valve tags disappear after spec update
6 REPLIES 6
Attila.Vallyon
655 Views, 6 Replies
Hello!
This problem still not fixed in P3D 2012. All of my valve tags disappears after I update the spec.
This is very annoying. Please release a fix or something!!!
Thanks in advance!
Attila Vallyon
6 REPLIES 6
That must be a difficult problem if nobody answers!!!
Attila Vallyon
in reply to: Attila.Vallyon
I'm having same problem.
In version 2012 I also had this problem, but the 2013 version does not. Now you can update the spec that will not lose the tags of the valves.
milic.srdjan
Hi to all,
This is old theme, but it seem that same situation can appear in
Autocad Plant 3D 2019.2 update.
case 1: I have PlaceHolder Metric component (a valve), and if I change it to appropriate spec (via drop down option), I loose Code and Number of valve
case2 : I have, in pipe class XXX hand valve, and change whole pipe line with valve to pipe spec XXY, my hand valve loose Code and Number (and completely tag)
I think that normal work flow is possibility to change pipe specs, but valves need to keep their Tag Numbers
Thank you in advance,
Srdjan
milic.srdjan
in reply to: milic.srdjan
Is this Answer on my problem.
https://knowledge.autodesk.com/support/autocad-plant-3d/troubleshooting/caas/sfdcarticles/sfdcarticl...
Issue:When substituting a tagged valve, the formerly filled tag format properties are empty afterwards.
Causes:Missing delimiter in the tag format definition.
Solution:Add a delimiter between the tag format rows
This is so stupid, THIS MUST BE WARRING WITH CAPITAL LETTERS,
no words just,  "oh you Autodesk" !!!!
What this above mean, I can not use Valve Tag without any delimiters between valve CODE and valve NUMBER !!!!
Angry Srdjan
I had experience this issue using Plant 3D 2022 for valve tags. Unbelievable, it's been 10 years and no permanent solution.
