Valve Operator Position
Vikram.Joshi
Vikram.Joshi
Hello, In plant 3d parametric valves the lever position is parallel to pipe or in open position , can I change this to close or 90 degree to pipe
George.Endrulat
Yes and no, the default ball valve actuator is lacking in options for rotation:
You can however create a new ball valve handwheel with any orientation you want in python.
George
If my post offers a solution, please click "Accept as Solution"
Vikram.Joshi
Can you Please suggest me where is the position parameter in below script
