Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Valve End Iso Line Number Not Showing
DW-KIM
DW-KIM
Hello friends.
I hope someone can help me
My client wants to write the drain line as Valve End.
In this case, if you model as follows, the corresponding line number does not appear on the Iso. What would you like to do in this case?
I know that if I draw a line on the opposite side of the valve even a little, the line number will come out. However, the client wants the finish to be a valve.
h_eger
Dear @DW-KIM ,
Please change in the project configuration of Plant 3D under
Isometric DWG Settings -> "Your Iso-Style" -> Override -> Small Bore Piping -> Smallbore includes size up to -> "Your smallest available nominal diameter"
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
DW-KIM
Dear @h_eger
 Thank you. I have a question, is there a case to turn off the small diameter option in ISO config.xml? I want to write without distinction between small and large diameters.
h_eger
Yes, as I wrote in my post about project configuration etc.
Point 1-4
Hartmut Eger
Senior Engineer
XING | LinkedIn
