Update Ortho Views via API
tom.povey
Message 1 of 15
tom.povey
Is it possible to update Ortho views via the Plant3D API?
I'm able to get all the views associated with an Ortho drawing, but i can't find any method related to updating or generating an ortho view.
Any help is appreciated.
Tom
Replies (14)
Message 2 of 15
jabowabo
I don't see anything. Depending on the context, you may can grab the view object ID(s) and use one of the various 'send command' methods: Editor.SendCommand, Document.SendStringToExecute, Editor.CommandAsync
Message 3 of 15
tom.povey
Unfortunately the command doesn't take any arguments to specify which view you would like to update, so send command methods won't work.
Do you know where i can find documentation for the COM API? I've only looked at dotnet.
Cheers for looking
Message 4 of 15
jabowabo
I don't know of any other documentation. This looks promising:
You could potentially iterate the views, test for type, and update each. I don't see how to check for which views are outdated but haven't looked real close.
Message 5 of 15
tom.povey
Does look promising! Can't seem to find how to get the PlantOrthoView though, doesn't seem to inherit a View or Viewport. Maybe it's private?
Message 6 of 15
jabowabo
maybe a try/catch to open every object id in paper space as an ortho view. Once you find it, you could reverse engineer from there.
Message 7 of 15
tom.povey
No luck, can't even find anything that inherits PlantOrthoView. I've even iterated over every object in the drawing but no luck. Hopefully autodesk can get back to us with some more info!
Message 8 of 15
tom.povey
Anyone have any ideas?
Message 9 of 15
mobworld
Select the view with mouse and execute a command comtaining :
Autodesk.ProcessPower.PnP3dOrthoDrawingsUI.PlantOrthoView view = new Autodesk.ProcessPower.PnP3dOrthoDrawingsUI.PlantOrthoView(true, true);
view.updateOrthoView();
This will update the view selected.
Instead of select the view with mouse, do it using the API instead
Message 10 of 15
jomar_hipolito
Have you ever inserted using CreateOrthos()?
Do you know to specify the insertion point of viewport using Plant 3D API C#.
Thank you.
Message 11 of 15
jabowabo
Thank you.
Sorry, I do not have any experience with this method.
Message 12 of 15
phantritech
Message 13 of 15
jomar_hipolito
thank you
Message 14 of 15
jomar_hipolito
hello, do you know how to select the viewport and read the blockreference inside the viewport using plant 3D API .net? thank you
Message 15 of 15
jomar_hipolito
Hello, do you know how to trigger mouse left button using AutoCAD API?
I am inserting viewport using CreateOrthos, but I need to manually click a point on the paper space to insert the viewport.
On this image I need to click using mouse to insert it, or type a number then enter to insert it.
Is there a code in Plant3D API so I can trigger the left click on mouse or connect to the text screen to insert a point.
I tried using sendCommand, but it will wait for me to click or insert the viewport manually before implementing the sendCommand
