Update component after making spec changes
ljboxer1983
Message 1 of 8
ljboxer1983
Hi Guys,
I have done a model for a client, and they have now asked me to change the sizes of a couple of valves,
So I have updated the spec in spec editor and updated and reloaded it back in, but how do I update components which have already been placed?
Replies (7)
Message 2 of 8
h_eger
dear @ljboxer1983,
Like everyone else, "MANUAL"
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 8
ljboxer1983
Do you mean, delete and replace?
Message 4 of 8
h_eger
Yes, unfortunately, this is not possible in one step. But sometimes it does not work completely with the spec update.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 5 of 8
Dadspackard
@ljboxer1983,
No need to delete and replace
See screencast
Tom
aka, Dadspackard, Packin31
Message 6 of 8
ljboxer1983
Tom im not quite sure, what I have learnt from that, I appreciate you can change the size of a valve in the model, but what if you change its properties within the spec editor?
Message 7 of 8
Dadspackard
@ljboxer1983,
I may have miss understood your posted question.
As i read it I thought you asked that they changed the size of the valve lets say from 3" to 4"?
Or are they asking you to change the actual psychical dimension of the valves? If that is the case make a copy of the valve in the catalog change the dimension of the copy valve to the new dimensions.  Add this copy valve to your spec. Back into your model select the valve and then use the Substitute Part and select your newly added valve.
Tom
Message 8 of 8
meisam.abed
Thank you so much, your solution helped saved me!
