Unknown command - endp, cen etc...
DmitryKhot
Message 1 of 8
DmitryKhot
Hi all
Simply, quietly worked in Plant 3d 2017... Simple: I wanted to attach the valve to the flange - Right-Click + Shift - End Point.
...AND...
_endp Unknown command ENDP.
All the snap ceased to work: endpoint, center. node...
OK.
1. Reinstal Plant 3D - does not help!
2. Reinstal Plant 3D + deleting all Autodesk folders + deleteing all registry keys - does not help!!
3. Switch user (!) and creating new user - Does not help!!!
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...Does not help!!!
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-... - DOES NOT HELP!!!
What other solutions can there be?
Replies (7)
Message 2 of 8
Ruffy85
you has to be in a command to use the osnap functions.
same error inside line command?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Message 3 of 8
DmitryKhot
No...
Now (after cleaning and re-installing) I just draw line and want use osnap command.
As
line (and draw line)
right click + shift
...and - Unknown command 😞
Message 4 of 8
Bernd.Gerstenberger
Autodesk Support
Autodesk Support
Hi Dima,
I have created a video with audio for you.
Please, let us know if I could help you.
Regards
Bernd G.
Senior Product Support Specialist
Message 5 of 8
jabowabo
Verify DEMANDLOAD is set to 3.
Message 6 of 8
hi,
i have the same error too. it was working after line is completed too. then suddenly it stoped working. after looking at the video i try to add the line command and press shift + end point. it was working when i did that. how do i go back and use object snap without in the command like before. i searched online your only one to answer this.
looking forward to your reply
thanks
Message 7 of 8
hi,
could you please explain in detail please?
Message 8 of 8
jabowabo
Type the command DEMANDLOAD and make sure the value is 3.
