Hi All,
i want to set unique tag also for Speciality Items, but with no results.
I have followed this guide.
Follow my settings (I have modified only processpower.dcf because piping.dcf seems to be locked):
Anyone can help me?
The tag for speciality items is the standard tag. I have set under Type the string EJ.
Solved by Dan.Scales. Go to Solution.
Hi @Anonymous,
I have tested the steps in the article and they work for me.
Looking at your screen shots, the only concern I have with your setup is the PnPGuid format.
What SQLite editor are you using?
I use SQLite Expert Personal. Maybe try that and see it it helps.
If not, would you be happy to send me your project to look at?
Dan
Thanks @Dan.Scales,
I previously used DB Browser for SQ lite. Now I test with SQLite Expert Personal and seems to be ok!
Bye
