HI Senior and user,
I have a problem to show grating (hatch) on orthographic drawing in Autodesk Plant 3d 2023. Before this im using Version 2021 and grating was shown and no issue.
Grating and structural drawing design by use Advance Steel. Then the model xref to the Plant 3d model.
Hot Fix and enable has been install but still grating didnt show.
Please someone to assist on this.
If not the last option is re-install again version 20121. Attach snapshot a sample for references.
Solved by h_eger. Go to Solution.
Dear @Hazrul.MDNASIR ,
This seems to be a problem with AutoCAD Plant 3D 2023. Please report to Autodesk's Plant 3D Support.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
thanks for the response. can guide how to report to Autodesk Plant 3D Support? or any direct email to the support?
