Unable to define catalog components by size from STEP files - Plant 3D 2025 & 2026
jiri.opalecky
Message 1 of 9
jiri.opalecky
Hello
I usually create component catalogs from STEP files, but today I started having a problem. When I create a component, a link is automatically inserted into all sizes, and when I start directing the component to the correct block, the blocks for all sizes are overwritten. It started today and is happening in both Spec Editor 2026 and on my other computer, where I have version 2025. Where is the problem?
@jiri.opalecky Your post title was modified to add the product name and version and to increase findability - CGBenner
Replies (8)
Message 2 of 9
CGBenner
@jiri.opalecky
Hello, do you still need help with this question?
Chris Benner
Message 3 of 9
rossler.conrado
I have the same issue, can´t find the solution.
Message 4 of 9
jiri.opalecky
Hello
This problem is still relevant for me. After discovering the problem, I purchased parametric libraries, which allowed me to work around the problem at that moment, but now I need to use a precisely prepared library based on step files for my project again, and I am unable to assemble the catalog element. When I enter a prepared block for one size, all sizes are overwritten.
Perhaps I am making a mistake, but I was able to create elements this way without any problems until August
Jiri
Message 5 of 9
Michiel.Valcke
If I correctly understand, everything goes well up until PLANTPARTCONVERT, but when you map the blocks to individual sizes of your component in the catalog, each size mapping overwrites the previous size mappings?
If so, I can't reproduce the problem here. Are you able to share your .dwg file containing the imported step parts before using PLANTPARTCONVERT?
Message 6 of 9
Michiel.Valcke
@jiri.opalecky @rossler.conrado
I recently became aware of another issue that sounds similar, but it should be limited to parts created in version 2026
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Same-block-is-used...
It is currently still under investigation
Even though you get the same behaviour in your other computer where you use 2025, you can try to make the part again from scratch in the 2025 version of the spec editor and see if you get the correct result.
Message 7 of 9
gianni.bellu
Observer
Observer
we have same problem, i find only this post about this
Message 8 of 9
Michiel.Valcke
hi @gianni.bellu
Until Autodesk resolves the issue, you can install the 2025 version and create your components there. If you do, the problem should be avoided. You can still use a spec/catalog created in 2025 spec editor with a 2026 Plant 3D installation.
Message 9 of 9
lauri_barnhart
Hello, @gianni.bellu,
Did the information provided by @Michiel.Valcke help you and answer your question?
If yes, please click on the "Accept as Solution" button. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Lauri | Community Manager
