unable to create orthographic view while using 3D model selection
yogesh_sankpal_pune
yogesh_sankpal_pune
create ortho view single file there is no issues, while using selection model option or attached xref file orthographic view is missing please tell what i do thanks in advance.
single file
ortho view created ok.
error with
file added from 3d model selection option
result with missing view
AndyDavisArkance
Do you see anything if you select All Hidden Lines in the Ortho Editor ribbon?
Is there a solid object in the INSTRU file that is hiding everything below, possibly in a layer that is turned off?
You need to use PLANTHIDE to hide objects in the reference models that you do not want to show in the ortho.
Andy Davis
Industry Specialist
ARKANCE
yogesh_sankpal_pune
thanks for reply & problem solved there is some block of outside import that's error i deleted that & ortho reflected.
