Try to change my Dimension order on Generated ISO's
Often when I generate ISO's I find that my overall dimension is under my secondary line dimensions.  I've looked in the isoconfig.xml file to try to change this but haven't been able to figure it out.  I attached a file to help understand my dilemma.
Thank you
Tony.Kuharski.MEGI
That should be handled by the isoconfig.xml, you were looking in the right place.
Find the theme that is producing those dimensions (probably Default theme). In that section you will see the DimensionType tags, one each for Overall, String, and Locating. These tags should each contain a StackOrder setting equal to 1, 2, or 3. That is what defines the order those dimensions are placed, with 1 being closest to the pipe and 3 furthest.
The default should be set to Locating 1, String 2, and Overall 3.
