Trim Solids Using Curved Shape
a.akkawi123
a.akkawi123
Hi Team
I'm drawing a liquid separator (cylinder tank) with associated piping, the bottom 2 pipes are extending inside the filter tank as shown in the attached dwg. I would like to trim them using the tank wall (cylinder) so that the pipes will only start from the tank wall and extend to outside (thus I want to remove the inside extensions of those 2 pipes). How can I do that?
Appreciating your support with thanks
Antony
jabowabo
You'll have to explode the pipe down to 3D solids to cope them. Then you can use the SUBTRACT command.
