Transfering symbols and data from new projects to old projects
This widget could not be displayed.
Hi, how do you copy/transfer P&ID symbols from new projects to old projects?
Replies (7)
thebearjed
copy your projSymbolStyle.dwg from the old project to the new project. (always create backups first)
Thanks for that.
Do you know how to transfer report settings from one project to another?
Vasu27
Hi @Anonymous ,
I assume, you mean report template, which will work fine with the new project too, as long as all the properties configured in that template are also available within the new project. you just have to switch the project in Report creator window.
Vasu
There is a product called Plantools Sync, that does synchronization bewteen projects, but it is not for free.
https://www.auxalia.com/en/produkte/planttools/
thebearjed
Report Template is the same. just copy into your new project. i like to keep the files that i reuse on a separate network location and/or Autodesk Drive & external HD. maintain them there and copy to new projects.
I tried copying the report template file but i get an error as it cannot recognise it.
