The object reference is not set to an instance of an object for custom made elbo
DGRL
Advisor Advisor
DGRL
Dear forum members and Autodesk,
I made an custom elbow for use in my project.
Now I have 2 line numbers i.e. 202 and 203
see screenshot ( the selected part is pipe 202 and non selected is 203)
When generating an iso of pipe 203 I got no errors
When generating an iso of pipe 202 the system gives an error The object reference is not set to an instance of an object. and does not produces an iso
Does anyone know what is causing this?
I used the same elbow from same spec yet its not producing an iso
best regards,
If this was of any help please kudo and/or Accept as Solution
Kind Regards
DGRL
Dear memebers,
I get the same with pipe 2 pipe.
The main pipe ( the blue one ) generates an iso and even refers to the white small pipe ( under the blue 1)
When generating an iso from the small pipe I got the same error as with the elbows
Does anyone know what is going on?
Are my settings wrong?
Best regards,
Kind Regards
ryan.bales
Autodesk Support
Autodesk Support
What Version of Plant?
What type, symbol/skey?
Is it block based or parametric?
Catalog or custom part?
What type of connection between parts? Tap?
Ryan Bales
Fusion 360 Product Support
DGRL
Plant 3d 2016 to begin with lol
the first pic,
 the pipe = TYPE=PIPE
the bend = TYPE=BEND,SKEY=BEBW
The clamp = TYPE=CLAMP,SKEY=CLVT
the bend is block based and the clamp is parametric
the clamp is catalog part and also the pipe but the bend is custom made
For the first picture it is PL pipe end and GRV end for the bend ( no errors when connecting them )
the second pic is the pipe and bend standard catalog ( parametric )
but the flanges and the valve is block based
the valve =TYPE=VALVE,SKEY=VBFL
the flanges = TYPE=FLANGE,SKEY=FLSO
the problem with the second pic is the connection between the run pipe and the branch.
When deleting the branch connection then the iso will generate without a problem
Though I need references to the run pipe and the connection needs to be remained
Best regards,
Kind Regards
DGRL
Hi @ryan.bales
Do you want to have the DWG?
So you can see in your own environment?
Best regards
Kind Regards
DGRL
Hi @ryan.bales
I think the issue is fixed
Seems to be a spec update that was needed
After filling in the pressure class of all the components all of a sudden the iso's generated without any issue
Never knew that the pressure class could become a problem when generating an iso 🙂
Kind regards
Kind Regards
ryan.bales
Autodesk Support
Autodesk Support
I didn't either! But if it wasn't matching up properly and it was required it would make sense.
Ryan Bales
