Tee symbol not showing well on ISO
990433003T4E9
990433003T4E9
When i make a ISO, the symbol for a tee is not showing well. The content iso symbol definition=TYPE=TEE,SKEY=TESW. and when i try to do it with a tee from another type of pipe it does show it right.(see pictures)
h_eger
Please contact Autodesk Education.
Because you are using a student version of Plant 3D.
The support for this is explicitly for the education department at Autodesk
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
jabowabo
That looks like a custom tee. Just a guess but maybe you defined the ports incorrectly. Should be ports 1&2 for the main run and 3 for the branch.
990433003T4E9
Yeah that worked thank you!
Type a product name
