TAP Weld on isometric
mauro_spadaro
mauro_spadaro
hi,
system uses 2 different criterias for tap weld component.
  1. when inseritng a pipe2pipe connection it places a tap weld with branchind size , see attach file 3/4" (DN20)
  2. when inserting a sockolet 4"x 3/4" it places a tap weld 4" (dn100) that is a mistake because the weld is nearly the same as for pipe2pipe connection.
which is the way for having correct size of tap weld? In both cases I would like to have tap weld 3/4" (DN20).
I'm using Plant 2018. Is the new function inside 2019 for TeeSize (ShowAllPortSize) on Isometric solving also this situation?
see attached images:
  • tap-weld-datamanager : tap welds are different, one 4" (DN100) and the other 3/4" (dn20)
  • tap-weld-isometric: tap welds are different as for point 2)
mauro_spadaro
news by anyone?
Hi, Mauro
Did you solve this issue? I have same problem.
DGRL
Do you have the dwg for us? I am unable to reproduce this in the 2022 version
If this was of any help please kudo and/or Accept as Solution
Kind Regards
davide_imberti
Hi, Mauro
