Supports on Supports
Artem_Marinin
Artem_Marinin
Hello сolleagues!
Can the PlantSupportsOnSupports command group Beam Bolted Trapeze Hanger and Clamps?
Thanks in advance!
Best Regards,
Artem Marinin
JUANCARLOSBLASCO4129
Artem_Marinin
Hello @JUANCARLOSBLASCO4129
Thank you for your reply.
Now I don't need to group supports in ISO. I can't group them even in 3D. So I'm interested in whether there is a way to do it. I'm talking about Beam Bolted Trapeze Hanger and Clamps (or analogs).
Best Regards,
Artem Marinin
Are you saying you would like to have a single support callout that has the 2 supports you are showing?  If so, that would be custom.  We can do custom supports.  Check out our Steel Supports Bundle for Plant 3D (https://www.youtube.com/watch?v=hG7T_DQkHU4&t=13s) at www.asti.com/SteelSupports for more info.
Artem_Marinin
Hello @Anonymous,
thank you for your reply.
Not quite so. I would like to have two supports in 3D, two callouts in ortho, two supports in BOM, but if I move a pipe in 3D two supports would follow the pipe. Now when I move a pipe, only clamp follow it and I'm forced to move the hanger manually. It takes extra time.
Best Regards,
Artem Marinin
Scott.Hallmark
I see what you mean now.  However, I am not experiencing the same issue.  I place 2 supports on the pipe, and then do a supports on supports command and it works fine when I move the pipe. Out of curiosity, does this happen on any dwg you have or have you only experienced it in one drawing?  Have you tested it in another project?
** If my reply resolves this issue, please choose Accept Solution **
Scott Hallmark, Design Specialist | Fluor Corporation
Inventor and AutoCAD Certified Professional, Autodesk Certified Instructor | My Plant3D Notes | AU Speaker | ROLL TIDE!
Artem_Marinin
Hello Scott,
Yes, I have tested it in other projects, in P3D 2015 and P3D 2017. The same result. By the way, trapeze support doesn't connect even with pipe: when I move the pipe, trapeze stay in the same place. Support On Support function works good with other types of support, e.g. Dummy and Shoe. But I need to group Trapeze and Clamps.
Best Regards,
Artem Marinin
