SQL logic error
SQL logic error
len.krenzler
SQL logic error
len.krenzler
Has anyone seen this before?  I have no idea what happened.  One day it was working, the next it was not and I can't think of anything that changed.  Any help much appreciated.
SQL logic error no such column: Service
len.krenzler
A local expert was able to help.  In case anyone else has this issue, the solution ended up being this:
Run PnPLocalDataCachePurger.exe from the programs files.
No idea why this had to be done, but it worked.
h_eger
Dear @len.krenzler ,
Why you should run the PnPLocalDataCachePurger.exe is a very simple reason. Over time Plant 3D saves local files in the folder provided for this purpose.
by executing PnPLocalDataCachePurger.exe these cached data will be deleted and Plant 3D will start again as new.
once a week prevents such error messages
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
