AutoCAD Plant 3D Forum
Spindles on Instrument-Angle Valves
1 REPLY 1
jgarzaM6SUZ
558 Views, 1 Reply
I have read a few post about adding spindles to instrument-angle valves. I am still not clear as to make this happen. From my reading the manual valves react differently from instrument valves when it comes to topworks. I am struggle with adding any type of topworks on the isometrics. I have followed a few forums but have been unsuccessful. All I get is the valve symbol. Can someone tell if this is even possible with instrument valves?
  1. Our relief valves must be instruments (Type:Instrument-Angle and skey:RAFL OR A NEW ONE RZFL)
  2. Added the following line ( <SkeyMap SKEY="RAFL" AcadBlock="ValveAngle"/> or <SkeyMap SKEY="RZFL" AcadBlock="ValveAngle"/>)
  3. Added to spimdle section ( <ValveToSpindleSkeyMap ValveSKEY="RAFL" SpindleSKEY="02SP"/> or  <ValveToSpindleSkeyMap ValveSKEY="RZFL" SpindleSKEY="02SP"/>)
1 REPLY 1
h_eger
in reply to: jgarzaM6SUZ
Dear @jgarzaM6SUZ ,
to make it easy, instruments do not have a spindle.
There is also no ISO class "INSTRUMENT-ANGLE"
Spindles only work with VALVE
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
