AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
spec to excel export error
5 REPLIES 5
dharunkumar.am
239 Views, 5 Replies
when I try to export spec to excel in AutoCAD 2022 .I get this error . I  tried running spec editor as admin too it didn't work . can anyone give me a solution for this .
5 REPLIES 5
@dharunkumar.am please try to export with C drive path.it will give error with OneDrive path.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Thanks for the reply . As you mentioned I tried with C drive path too . It still shows same error.
fyi, I exported 8 specs without error only one spec shows this error.
I have this error on one spec using Plant 3D 2022 as well.
If you have previous version or new version of Plant 3d ,Try in that . It may work .
