AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Select and Zoom Nozzle using C#
4 REPLIES 4
sambhaji_burungale
268 Views, 4 Replies
Hello Everyone,
I want to implement select and zoom feature for Plant3d components using their PnPID.
For select and zoom, I am using SelectObjects and ZoomObjects methods of Autodesk.AutoCAD.Internal.Utils as shown below.
List<ObjectId> objectsToBeSelected = new List<ObjectId>();
var pnPObjIds = dataLinksManager.FindAcPpObjectIds(nozzlePnpId)?.ToList()
if (pnPObjIds?.Count > 1)
    var target = dataLinksManager.MakeAcDbObjectId(pnPObjIds.First());
    if (target != ObjectId.Null)
        objectsToBeSelected.Add(target);
        Autodesk.AutoCAD.Internal.Utils.SelectObjects(objectsToBeSelected.ToArray());
        Autodesk.AutoCAD.Internal.Utils.ZoomObjects(false);
It works fine for piping components and equipment. However, the SelectObjects method needs objectIds as input. And for Nozzles, the MakeAcDbObjectId method always returns ObjectID of owner equipment.
I tried below approaches to get the objecdID of nozzle. But it did not work. It seems SubParts does not have object id.
var pnPObjIds = dataLinksManager.FindAcPpObjectIds(nozzlePnpId)?.ToList();
var db = Application.DocumentManager.MdiActiveDocument.Database;
var componentDBObject = db.TransactionManager.StartOpenCloseTransaction()?.GetObject(target , OpenMode.ForRead);
if (componentDBObject is Equipment equipment)
    var nozzles = equipment.AllSubParts;
    foreach (NozzleSubPart nozzle in nozzles)
        if (nozzlePnpId.Equals(nozzle.PartSizeProperties.PartId))
            var nozzletarget = nozzle.Id;   // This is always Null. (ObjectId.Null)
            var acPpObjId = dataLinksManager.MakeAcPpObjectId(target, nozzle.Index);
            target = dataLinksManager.MakeAcDbObjectId(acPpObjId); // This still gives owner equipment ObjectID.
            	break;
I was able to highlight the nozzle using below code. But still no luck for actual selection (that happens with control key + mouse click) and zoom. Any guidance with this issue will be greatly appreciated.
            using (Transaction tr = doc.Database.TransactionManager.StartTransaction())
				Entity entity = tr.GetObject(target, OpenMode.ForRead) as Entity;
				ObjectId[] entId = new ObjectId[] { entity.ObjectId };
				SubentityId subentity = new SubentityId(SubentityType.Null, new IntPtr(nozzle.Index));
				FullSubentityPath path = new FullSubentityPath(entId, subentity);
				entity.Highlight(path, true);
				PnPRow[] subpartrows = dataLinksManager.GetPnPDatabase().Tables["EngineeringItems"].Select($"PnPID={nozzlePnpId}");
				if (subpartrows.Length != 0)
					 // Implement Zoom with subpartrows[0]["Position X"],subpartrows[0]["Position Y"],subpartrows[0]["Position Z"]
				tr.Commit();
				break;
Thank You!
Sambhaji Burungale
4 REPLIES 4
Thank you Jason!
I tested Zoom with code provided in link. Mostly, it worked. However, sometime zoom just does not happen if I have zoomed out to see entire drawing. As a workaround, I tried following and it worked mostly.
1. Select Equipment
2. Zoom Equipment
3. Clear Equipment Selection
4. Zoom Nozzle
// Select and Zoom Equipment
Autodesk.AutoCAD.Internal.Utils.ZoomObjects(true);
// Clear Equipment selection so that the nozzle selection will be visible.
doc.Editor.SetImpliedSelection(new ObjectId[0]);
objectsToBeSelected.Clear();
// Zoom Nozzle
var nozzlePnPRow = pnpDb.Tables["EngineeringItems"].Select($"PnPID={nozzlePnpId}").FirstOrDefault();
if (nozzlePnPRow != null)
	ZoomToPoint(new Point3d(Convert.ToDouble(nozzlePnPRow["Position X"]),
									  Convert.ToDouble(nozzlePnPRow["Position Y"]),
									  Convert.ToDouble(nozzlePnPRow["Position Z"])));
public static void ZoomToPoint(Point3d pCenter)
	var ed = Application.DocumentManager.MdiActiveDocument.Editor;
	using (var view = ed.GetCurrentView())
		var UCS2DCS =
			(Matrix3d.Rotation(-view.ViewTwist, view.ViewDirection, view.Target) *
			Matrix3d.Displacement(view.Target - Point3d.Origin) *
			Matrix3d.PlaneToWorld(view.ViewDirection)).Inverse() *
			ed.CurrentUserCoordinateSystem;
		var center = pCenter.TransformBy(UCS2DCS);
		view.CenterPoint = new Point2d(center.X, center.Y);
		ed.SetCurrentView(view);
Do you have any suggestions for selecting nozzle?
In drawing, we use control key and mouse click to select nozzle. Can we achieve this using SDK?
Thank You,
Sambhaji Burungale
I'm not aware of any method for this.
Thank you @jabowabo, for the assistance.
Finally, I have found solution!! The trick was to use  SetImpliedSelection(SelectionSet selectionSet) method of editor. Here is the complete solution..
public void SelectNozzle(int nozzlePnpId)
	if(pnPObjIds?.Count == 0)
		return;
	if(target == ObjectId.Null)
		return;
	if (Runtime.IsPnP3dEquipment(target))
		Document doc = Application.DocumentManager.MdiActiveDocument;
		var equipment = doc.Database.TransactionManager.StartOpenCloseTransaction()?.GetObject(target , OpenMode.ForRead) as Equipment;
				SelectSubentity(target, nozzleEntity.Index, SubentityType.Face);
				break;
public void SelectSubentity(ObjectId target, int subEntityIndex, SubentityType subentityType)
		SubentityId subentity = new SubentityId(subentityType, new IntPtr(subEntityIndex));
		var gsMarkers = entity.GetGraphicsMarkersAtSubentityPathIntPtr(path);
		if (gsMarkers.Count > 0)
			var selectedSubObjects = new SelectedSubObject[]
				new SelectedSubObject(path, SelectionMethod.NonGraphical, gsMarkers[0])
			var selectedObjects = new List<SelectedObject>
				new SelectedObject(target, selectedSubObjects)
			var subEntitySelectionSet = new SubEntitySelectionSet(selectedObjects);
			doc.Editor.SetImpliedSelection(subEntitySelectionSet);
		tr.Commit();
// I was not able to use SelectionSetDelayMarshalled class present in SDK
// as it could not be instantiated. So, I had to write my own.
public class SubEntitySelectionSet : SelectionSet
    List<SelectedObject> selectedObjects = new List<SelectedObject>();
    public SubEntitySelectionSet(IEnumerable<SelectedObject> selections)
        selectedObjects.AddRange(selections);
    public override SelectedObject this[int index] => selectedObjects[index];
	public override int Count => selectedObjects.Count;
	public override IEnumerator GetEnumerator()
        return selectedObjects.GetEnumerator();
	public override ObjectId[] GetObjectIds()
        return selectedObjects.Select(s => s.ObjectId).ToArray();
Thanks and Regards,
Sambhaji Burungale
Technology Administrators
