Routing PPL end type pipes in AutoCAD Plant 3D 2020
I'm having trouble routing a PPL end type pipe (3" ND and above) which connects to a PSW end. As I start routing I can specify any length for the pipes with no problems and also add a fitting (elbow). The problem starts right after the elbow is placed because I can't specify any length lesser than 4'. I've check all the joint connections and joint properties, the fixed length is off there's no cut length set.
How can I enter the length value of my desire after placing a fitting in this case?
Thanks in advanced.
Replies (0)
