Rotate Structural Members
11:10 PM
This is a bug that I found since I started to use Plant 3D 2018.
When inserting a structural member and is rotated along the length axis using the rotate command and then use a grip on the steel section to stretch it out and it will flip back to the default rotation position from when it was inserted.
This has a work-around by using the edit member to change the rotation.
Using rotate has worked in all versions prior from 2010 to 2017 and is a far quicker easier way of rotating a structural member, especially given there is no preview in the member editor.
I haven't used 2019 to see if this problem still exists.
I have all the latest updates installed for 2018. A hotfix or patch would be great to fix this.
Scott
