AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
regarding Welding Number sequence on more that one isometric sheets
4 REPLIES 4
736 Views, 4 Replies
Hellow,
When we generate isometric in more than one sheet, welding numbers starts from 1 on second sheets also. But it should not start with no. 1.  It should take next number (where sheet no 1’s welding number finishes )on second sheet.
Please provide solution ASAP for this query.
Thanks in advance.
4 REPLIES 4
h_eger
Dear @Anonymous ,
Ever tested with "Reverse Iso Start and End Point" (1)?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
in reply to: h_eger
Dear Sir,
Please find attached snap1. I am using 2019 version and the option is not present in this version.
Please guide for the same.
Gokhan_Kaya
Hello @Anonymous
You can create iso Sheets by countinuous weld number
Follow the procedures in the link below
https://knowledge.autodesk.com/support/autocad-plant-3d/learn-explore/caas/sfdcarticles/sfdcarticles/How-do-I-create-sheet-overlapping-weld-lists-with-continuous-numbering-in-AutoCAD-Plant-3D.html
GK
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" ("Accept as Solution") seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" ("Kudo") ile ödüllendirin.
Gökhan Kaya
Tehcnical Manager
Autodesk Inventor Certified Professional 2015
LinkedIn
MSI WS 60 i7 Quadro M2000M
in reply to: Gokhan_Kaya
Dear Sir,
Thank you very much for this solution.
I am facing one more issue, after the setting when we extract the isometric welding number hasn't start on second sheet where it ends on first sheet.
Please refer attached files for more information.
Is there any setting or solution for above  query also? If any please let me know for the same.
Thanks in advance.
Anil Kumtole.
