AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
"Unhandled exception has occurred in a component in your application."
1 REPLY 1
1137 Views, 1 Reply
When I attempt to access my Table Setup in my title block setup I get this error message. Any idea how to fix this? Table Issue.PNG
1 REPLY 1
quentin.contreras
@Anonymous wanted to reach out to see if you were able ever to resolve this on your side. There is an Autodesk Plant 3D article that might be related to the error message you are seeing. Please refer to this article if you still needed help with this.
Error:" Unhandled Exception. PnPCompletionStatus.ColumnDoesNotExist" when using calculated properties in ISO BOM of AutoCAD Plant 3D
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
Technology Administrators
