Quick properties Tag
In Quick properties it is not possible to change the Tag if, when Properties is enabled, the Tag can be changed. Is it possible to change the Tag in Quick properties without activating the Properties?
h_eger
Dear @Anonymous ,
I don't have this restriction for me to fill in the TAG with the Quick Properties.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Dear @h_eger
That's not how it works for me.
Without properties
With properties
h_eger
You're right, I didn't even notice that the property manager has to be open in order to be able to change the TAG via Quick Properties.
I don't think we can change this. You can ask Autodesk support if there is a solution for it, I don't know any solution for it ..
Hartmut Eger
Senior Engineer
XING | LinkedIn
