Python Script Image + Spec Editor Crashing
gerrardhickson
gerrardhickson
Hi All,
I have 2 related questions to do with Python scripts.
  1. My images don't show up. I've created 32, 64, 240 and 640 px images, they're named with same (with the size as a suffix - e.g. EF_ELBOW_32.png), and they're in the same CustomScripts folder, but they don't show up anywhere.
  2. When I try to create a new component in Spec Editor for one of my scripts, it crashes Spec Editor - no error messages or warnings, just gone.
    The script is below - it's for an Electrofusion 45deg elbow, but it was intended that the angle may change.
import aqa.math
import math
from varmain.primitiv import *
from varmain.var_basic import *
from varmain.custom import *
@activate(
    Group="Elbow",
    TooltipShort="EF Elbow",
    TooltipLong="Electrofusion Elbow",
    FirstPortEndtypes="PPL",
    LengthUnit="mm",
    Ports="2",
@group("MainDimensions")
@param(D=LENGTH, TooltipShort="Pipe Diameter 1")
@param(D2=LENGTH, TooltipShort="Pipe Diameter 2")
@param(L1=LENGTH, TooltipShort="Leg Length 1")
@param(L2=LENGTH, TooltipShort="Leg Length 2")
@param(R=LENGTH, TooltipShort="Elbow Radius")
@param(A=LENGTH, TooltipShort="Elbow Angle")
@param(S1=LENGTH, TooltipShort="Spigot Length 1")
@param(S2=LENGTH, TooltipShort="Spigot Length 2")
# (arxload "PnP3dACPAdapter") (testacpscript "EF_ELBOW45")
def EF_ELBOW45(s, D=200, D2=200, L1=232, L2=232, R=200, A=45, S1=104, S2=104, **kw):
    #### NOTE: ALL ANGLES ARE CLOCKWISE.
    # CALCULATIONS
    WT1 = 6  # PIPE WALL THICKNESS
    WT2 = WT1 * 2  # SPIGOT WALL THICKNESS
    # X1=max(L1-R,S1+10)
    # Y1=max(L2-R,S2+10)
    X1 = S1 + 10
    Y1 = S2 + 10
    # NOTE: GEOMETRY FUNCTIONS (ARC ETC) USE ANGLES AS DEGREES, BUT TRIG FUNCTIONS USE RADS.
    pi = 3.xxx-xxxxxxxx
    Arad = A * pi / 180
    T = min(L1 - X1, L2 - Y1)
    R2 = min(R, T * tan((pi - Arad) / 2))
    # R=max(R, L1-S1+1, L2-S2+1)
    Lx2 = L2 * sin(pi / 2 - Arad)
    Ly2 = L2 * cos(pi / 2 - Arad)
    # EXTERNAL SHAPES
    ## MAIN SPIGOTS
    C1 = CYLINDER(s, R=D / 2 + WT2, H=X1, O=0).rotateY(90).translate((-X1, 0, 0))
    C1inner = CYLINDER(s, R=D / 2, H=X1, O=0).rotateY(90).translate((-X1, 0, 0))
    C2 = (
        CYLINDER(s, R=D2 / 2 + WT2, H=Y1, O=0)
        .rotateX(-90)
        .rotateZ(180 + (90 - A))
        .translate((-L1 - Lx2, Ly2, 0))  # - Lx2, Ly2
    C2inner = (
        CYLINDER(s, R=D2 / 2, H=Y1, O=0)
        .rotateX(-90)
    # ## EF LUGS
    C3 = CYLINDER(s, R=10, H=D / 2 + 20, O=0).translate((-S1 / 2, 0, 0))
    C4 = CYLINDER(s, R=10, H=D2 / 2 + 20, O=0).translate(
            -L1 - ((L2 - S1 / 2) * sin(pi / 2 - Arad)),
            (L2 - S2 / 2) * cos(pi / 2 - Arad),
            0,
    # SELF-INTERSECTING ARC DOESN'T WORK. NEED TO CREATE A TORUS THAT'S CUT.
    # THE PRIMARY DIAMETER/RADIUS NEEDS TO BE LESS THAN THE SECONDARY RADIUS AND THE LEG LENGTH NEEDS TO BE TO PREVENT
    # THE SHAPE BEING SELF-INTERSECTING.
    A1 = ARC3D2(s, D=D / 2 + WT1, D2=D2 / 2 + WT1, R=R2, A=A).translate((-L1, 0, 0))
    A1inner = ARC3D2(s, D=D / 2, D2=D2 / 2, R=R2, A=A).translate((-L1, 0, 0))
    # ARC EXTENSIONS
    C1a = (
        CYLINDER(s, D=D / 2 + WT1, H=L1 - T - S1, O=0)
        .rotateY(90)
    C1b = (
        .rotateX(-90)
    C1aINNER = (
        .rotateY(90)
    C1bINNER = (
        .rotateX(-90)
    C1.uniteWith(C2).uniteWith(A1).uniteWith(C3).uniteWith(C4).uniteWith(C1a).uniteWith(
        C1b
    C1inner.uniteWith(C2inner).uniteWith(A1inner).uniteWith(C1aINNER).uniteWith(
        C1bINNER
    C1.subtractFrom(C1inner)
    C1inner.erase()
    A1.erase()
    A1inner.erase()
    C2.erase()
    C2inner.erase()
    C3.erase()
    C4.erase()
    s.setPoint((0, 0, 0), (1, 0, 0))
    s.setPoint((-L1 - Lx2, Ly2, 0), (-sin(pi / 2 - Arad), cos(pi / 2 - Arad), 0))
    return
Thanks in advance.
gerrardhickson
Ok - I just solved both problems.
Seems I forgot to run PLANTREGISTERCUSTOMSCRIPTS
h_eger
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
