Dear Autodesk,
I am getting a question from my customers about what programs can work with the Plant 3D database.
Elaboration,
Customer is using a program for maintenance ( unknown what program ) and wants to make a connection with the P3D database in order to connect that data to some maintenance sheets
Simply said like this.
We have an maintenance system running, can it talk with Plant 3D
I already told them that there approach is wrong and they need to look at the api / com interfaces.
Also look at the program they use to see what language it is written in and what import capabilities are in that specific program
Can someone please confirm to me what is correct?
Is there a list of well known ( maintenance like ERP ) programs / systems that works with P3D
If there is no such list can someone please elaborate how to approach this and if possible how I can explain how these things are really working in Plant 3D
If I am wrong please let me know.
Hope to hear from someone
Kind regards
I am not the authority or anything, but I find it HIGHLY unlikely that you will find what you seek.
The Plant 3D package is largely tied to DCF files and a DCF file is nothing more than an SQLite database with a different file extension. It would be entirely possible to make something that read information out of those, but I sure wouldn't want to undertake something like that. Coming at it through the .Net API (requires AutoCAD) is painful enough, but without the assists the API gives I would consider it more effort than it was worth to unravel/find the information
So, you could do exactly what your wanting to do with those, but if you wish to write back to the DCF's...... Well, I don't know if you can easily do that without causing corruption; it would be pretty dangerous territory.
Here are the relational diagram for the P3D database:
http://images.autodesk.com/adsk/files/PlantSDK_ERD.zip
"Works with" is a bit vague. What, specifically, is the goal? Tracking part ID numbers? Querying location? Tracking service history?
Plant3D is backed by a database, which may be SQLite or SQL Server, although for anything substantial the latter is pretty much a given. So anything that can query tables in a SQL Server database can read model data.
Have a read:
Hi @JHoward_HOB
Thanks for this email
The file you attached is nice and contains good info.
may I ask you where you downloaded this from?
I want to get the 2016 or 2017 version
Kind regards
Hi @DGRL,
It may be possible, depending on the type of database you are trying to connect and what you want to achieve:
External-Database-Reference-Manager
Drive AutoCAD Plant 3D and AutoCAD P&ID Data Using the External Database Reference Manager
Dan
Hi @Dan.Scales
Thanks for the reply
Just to clarify
What we want is a complete list of all the so called maintenance programs that can work with plant 3D
Simple as that
The maintenance program needs to be able to read data from P3D and/or P&ID.
The program then needs to process that data into sheets for maintenance engineers in the field to do maintenance.
I know already that there is no such list ( correct me if Im wrong)
Can you please provide me documents that explain how to work with API / com interfaces or any other tool that helps us to talk with other programs.
Kind regards
Hi @DGRL,
You are correct, the list you are asking for does not exist.
I also don't have any documents that explain how to work with API or any other tool that would help connect Plant to other programs.
My advice would be to contact the Autodesk Developer Network.
Dan
