Problem with loose flange collar connection
For my current project I'm using a pipe spec with loose flanges and collars with large lengths.
Large collar
When trying to connect these collars directly to each other (remove the small straight length in-between), I get the following error message:
I tried to alter some things in the project settings under "piping connection settings", but didn't get the result I want.
Can someone tell me what I should do to be able to place these collars directly onto each other?
I also don't see a weld-dot between the collar and pipe, maybe that has something to do with it.. (yes, toggle weld display is set on :))
(using Plant 3D 2019)
