Possible to exclude "existing" pipe on iso?
philip.kall
philip.kall
Is it possible to exclude "existing" pipe on iso?
The colored pipe is set as new and the grey pipe is set as existing.
Regards
Philip
Replies (8)
h_eger
@philip.kall ,
I am unable to offer you a functional solution to your enquiry.
Do you have an example of how your iso should look with the connection to an existing pipework
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
philip.kall
Thanks for you reply.
It is not necessary the show the existing pipe on the isometric because it is such a large part of the pipeline.
The new part of the pipe is only about 5 meters long and the existing pipe is about 50 meters long.
I only want the "green part" to be on the isometric, the rest of the pipe is existning.
Regards
Philip
Tomislav.Golubovic
Did you change the status of the existing pipe to "Existing"?
philip.kall
Yes, the pipe is set to status "existing" 🙂.
jflorita
I think you turned off the theme for Existing Piping, existing piping should look like this by default.
To enable it:
Project setup > Isometric DWG settings > Themes
philip.kall
Yes, I did turn off the theme for existing pipe. I updated the picture in my previous post now, thanks :).
But I still don´t want the dotted line either...
Tomislav.Golubovic
Change the line number of the existing line to something else, it'll only draw a small section of the line
jflorita
@philip.kall
Then just hide or delete the layer of the existing pipe, but as what @Tomislav.Golubovic said, you have to make a separate line number for that.
