PM: check boxes in "Area view" are not available for selection.
jw7018
jw7018
The visible (now greyed out) check boxes in "Area view" are not available for selection, once the tree gets to "Fasteners"  & "Pipe Run Components."
Is this normal or is there a way to check these boxes?
I would like to add a few rows to see in the data manager "Area view"
(yes I can filter for line number in the data manager via order by object type but this is to my first choice. )
h_eger
All values with * are superordinate. You can change these in the Piping and Equipment class.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
jw7018
I tried that earlier and get an error code that the name exists within the hierarchy under "Fasteners" and "Pipe Run Component."
It appears that if "Property Name" exist within a hierarchy (child) then it cannot be added to the (parent) ?
What is your suggestion? Thanks.
