AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
PlantProductionIso errors out with Process with and Id of .... is not running.
18 REPLIES 18
Message 1 of 19
matt.worland
941 Views, 18 Replies
I'm trying to run isos in Plant 3d 2025, but I get this error regardless of the Project or Iso style. Anyone seen this and have a fix?
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.ArgumentException: Process with an Id of 6336 is not running.
   at System.Diagnostics.Process.GetProcessById(Int32 processId, String machineName)
   at Autodesk.ProcessPower.PnP3dIsoUI.PnPIsoService.CloseIsoServiceProcess()
   at Autodesk.ProcessPower.PnP3dIsoUI.PnPIsoService.RecieveResponse(String jobdata)
   at Autodesk.ProcessPower.PnP3dIsoUI.PnPIsoService.Start(String jobdata)
   at System.Threading.Tasks.Task.<>c.<ThrowAsync>b__128_0(Object state)
   at InvokeStub_SendOrPostCallback.Invoke(Object, Span`1)
   at System.Reflection.MethodBaseInvoker.InvokeWithOneArg(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
I run the PlantProductionIso command, select my iso style and lines and push Create. Shortly after, the dialog closes as normal, but I get the error above.
After trying different projects and styles, I went to repair the install, but found I only had the option to uninstall. I uninstalled the software and then redownloaded and reinstalled.
I opened the Sample Project, selected the 6-B-1000_Piping model, ran the PPI command, chose the top three lines and hit create and get the above error.
Im running this on a Windows 10 laptop that has been running versions 2019-2024 with no issues. I haven't noticed any other issues in 2025, it seems to run normal beyond the inability to run isos.
Any thoughts
If my reply was helpful, please give a "Thumbs Up" or "Accept as Solution"
18 REPLIES 18
Message 2 of 19
DVaquand
in reply to: matt.worland
Hello Matt
If you run a quick iso, is the problem the same?
Have you installed the Plant 3D 2025.0.1 update?
== French ==
Si vous sortez un iso rapide, le problème est-il le même ?
Avez-vous installé la mise à jour Plant 3D 2025.0.1 ?
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
Message 3 of 19
matt.worland
in reply to: DVaquand
Hello Dominique,
Thank you.
I just verified that 2025.0.1 update was already installed.
Yes, I get the same results when running a quick iso.
I'm not sure of anything else to test, but happy to if there are any suggestions.
matt
Message 4 of 19
Is this on your Iso style or the OOTB ones?
Message 5 of 19
DVaquand
Hello Matt
By running a quick iso on parts of the line, and not the entire line, is there the error?
== French ==
En lançant un iso rapide sur des parties de la ligne, et non pas la ligne entière, y a t-il l'erreur ?
Cordialement
Dominique VAQUAND
www.dovaq.fr
Message 6 of 19
matt.worland
Thank you Tomislav and Dominique,
Currently, I'm running OOTB models and styles. It does happen with our models and styles as well.
It does not matter if I choose Production or Quick Isos.
Attached is a short video of the process and issue.
Message 7 of 19
Is this only on your machine or on others also?
Message 8 of 19
Just this machine
Message 9 of 19
Can you try with another user profile on that same machine?
Message 10 of 19
matt.worland
Good idea, I hadn't tested that, but still no luck.
I only had a single user on the computer so I needed to add another one.
I created a new local Admin user, signed in.
When I ran a Quick Iso on the same sample model, I get the same error.
Message 11 of 19
h_eger
Hi Matt,
somehow, P3D 2025 is always giving me faulty installations with strange error messages.
Uninstalling and reinstalling once has also helped me.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 12 of 19
DVaquand
Hello Matt
If you have a 2024 version on the same workstation, do you encounter the same problem in the isometric output?
== French ==
Si vous avez une version 2024 sur le même poste est-ce que vous rencontrez le même problème dans la sortie isométrique ?
Cordialement
Dominique VAQUAND
www.dovaq.fr
Message 13 of 19
jabowabo
From the error message, I'd first try to rule out an antivirus issue. Have you tried disabling it temporarily to see if the issue persists?
Message 14 of 19
matt.worland
in reply to: h_eger
Thanks Hartmut, I will try again with a full cleanup after the uninstall.
Message 15 of 19
matt.worland
Thanks Dominique,
All of my previous versions work fine.
Message 16 of 19
matt.worland
in reply to: jabowabo
Thanks Jason,
I disabled my main AV, but I think Windows Defender was on. I'll double-check when I re-install after a full cleanup.
Message 17 of 19
matt.worland
After another uninstall of Plant 3d 2025 and AutoCAD 2025, I removed all Folders and Registry settings for AutoCAD and P3D 2025. I removed my AV and disabled Windows Defender and reinstalled both AutoCAD and P3D.
At that point everything was finally working again.
Thank you Everyone for your help.
matt
Message 18 of 19
In my house we have two versions of Plant 3D 2025 student version, and both versions, on different machines, we have the same problem.
When generating isometrics the same error window appears. I have reinstalled Plant 3D twice with the same result.
Message 19 of 19
h_eger
@autodesk_student_soft_2025 ,
Plant 3D 2025 student version, the rules of the Education Forums apply and not the Plant 3D Forums.
Please read the licence conditions.
Hartmut Eger
Senior Engineer
XING | LinkedIn
