Plant3D vs SmartPlant vs Inventor
Hello all, I'm looking for some honest opinions from people that have ACTUALLY USED Plant3D and one of the other softwares.
My company designs small to pretty large water processing plants, where piping is a big component of what we do.
We used a company from India to support us with Plant3D on our last larger project as we didn't have in house experience with Plant3D yet, and not enough human resources to manage the project in Inventor.
I would considered myself to be quite proficient/advanced with Inventor having used it for the last 3 years and designed a few plants with it, using Tube and Pipe and Frame Generator heavily. We are also looking at using AutoCAD electrical and the Electrical Cable routing module of Inventor.
We have been spending the last couple month learning Plant3D, and I have to be honest, it's the worst program I have ever used, and after all this time I am still not remotely comfortable even doing the simplest designs. My coworker is of the same opinion, we have both learned several different CAD programs over the years (we both have over 20 yrs experience and not much hair LOL), and we are both incredibly frustrated with the stage we are at in getting up to speed with the amount of time we have put into this. It feels like this would be a great program if it was 1999, not 2023. There are some good features about it, but the based architecture of the program is severely dated and really flawed and all the dressing in the world can't make up for that.
My Boss comes from a background of using SmartPlant, and has zero experience using Inventor, and also has not actually used PLant3D. So she is more comfortable with the terminology and initial layout of Plant3D, but I get the sense that SmartPlant is a far superior and much more user friendly program. Here is a direct quote from somebody that has used both "Usually the modeling of an item which you can model in 1hr in SmartPlant takes you a day to finish in AutoCAD Plant 3D in a complex area."
She is really pushing for us to use Plant3D rather than Inventor, and I think this is because Inventor is just foreign to her, and she also doesn't realize the what I believe is a large gap between SmartPlant and Plant3D (to be fair, there is also a large $ gap between the two as well).
Using SmartPlant is not in the cards, we are not switching, but we are trying to make a strong case to use Inventor over Plant3D.
OK, so to start things off. The P&ID module of Plant3D seems quite useful and we are intending to use that, also the auto generated ISOs from Plant3D are amazingly quick to produce, which is a huge time saver. However because we have Plant3D and Inventor, you can also easily export a PCF from Inventor and create the ISOs using Plant3D, so this aspect is actually a moot point, not a plus for using Plant3D to model everything.
So outside of the extra processing power required to design in Inventor over Plant3D, I can't see a single positive reason to use Plant3D over Inventor for all the modelling. We have the processing power covered by having brand new specially developed CAD machines, and we have developed a modelling structure that does not require us to have very large assemblies open all the time, we have everything broken down into sub assemblies for each building and multiple sub assemblies for each building, so we rarely ever need each complete building open and almost never need the entire plant level open all at once.
Inventor is just a far superior program in every aspect, it's so much faster to model in and WAY FASTER to make edits and changes to existing equipment and piping runs. I also find the software more stable (less glitchty), and because components are constrained, the model is very stable, and you know where stuff is and it can't be moved with out you knowing about it.
So people that have used SmartPlant and Plant3D, am I correct, is it a much superior software?
Those of you that have used Plant3D and Inventor, is there any good reason to use Plant3D over Inventor?
I do want to hear if there are good reasons to use Inventor over Plant3D.
James
