AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Plant Run Component and Pipe on Excel sheet?
4 REPLIES 4
OPerezBC2SQ
149 Views, 4 Replies
Thank you guys for reading this post. I recently outputted the part list from the data manager to an Excel sheet, and two tabs showed up one called Plant Run Component and the Pipe. Was the difference between them and is the system counting for the pipe length on both Excel tabs or are they two separate entities?
thank you
OP
4 REPLIES 4
h_eger
in reply to: OPerezBC2SQ
dear @OPerezBC2SQ ,
can we please get full information to enable us to write a solution to problems.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
OPerezBC2SQ
Hartmut,
What is the difference between the two they seem to have a length column on each tab. So my question is, are they separate length counts or are they the same length count?
h_eger
Pipe = only the pipe parts
Pipe Run Component = all installation parts in your pipe run
Hartmut Eger
Senior Engineer
XING | LinkedIn
OPerezBC2SQ
THANK YOU
Technology Administrators
