Plant 3d P&ID create specific Tag Format
maltunPYN9L
Observer Observer
maltunPYN9L
Observer
Observer
Hello;
I want to add A/B as an option to the tag numbers of some of my equipment in the project. I also want it to be used without an option and follow the sequence number. I wonder if such a thing is possible.
for example: I have twin tanks. Tag: I am logging in as T-12501A and T-12501B. My next tank is not twin and I want the tag number to be T-12502.
I tried 3 different methods.
1- I set the option part to be manually entered into the "equipment tag" style independently of the tag format part. but when I typed A/B, it set the number as T-12501A T-12502B.
2- I added the option part to the Tag Format section. But in my non-twin tanks, after the tag numbers T-12501A, T-12501B, it appeared as T-12502?
3 - I prepared 2 different tag formats. one with option and one without option. this time, after entering T-12501A and B in my twin tanks, my tank with tag format without option started again from T-12501 from the first number.
Note: I added it to 2 different Tag Format sections by saying automatic number generation from within the project. but when I deleted it and robbed it again with the same tank, it started to follow the sequence number by skipping because it generated the sequence number as the one after I deleted it.
I wonder if there is someone who can help about the subject.
I continue to experiment, by the way.
h_eger
Dear @maltunPYN9L ,
Only one TAG is possible per class.
This can be done using various labelling options.
This has the disadvantage that the TAG is always noted in the DB and not your labelling.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
