Plant 3D object not showing properly in Naviswork Manage 2024
Ray_K
Ray_K
Here I am again. I tried installing the new Autodesk Plant 3D 2024, Advance Steel 2024 and Navisworks Manage 2024. The P3D and ADS objects graphics are show properly when opening both Plant 3D and Advance Steel application. But not in Navisworks. I tried to uninstall and reinstall several times and even change order of installation but seems not working. I also tried deleting nwc files before running Navisworks still not working.
I wrote down my installation order in installing 2023 versions but not working on 2024.
DVaquand
Hello
You need to download and install "Object Enabler" for Plant 3D.
Enter your Autodesk Account site
www.autodesk.com/account
Cordialement
Dominique VAQUAND
www.dovaq.fr
Si mon message propose une solution, veuillez cliquer sur "Accepter comme solution"
If my post offers a solution, please click "Accept as Solution"
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
Ray_K
Yes, Plant 3D Object Enabler downloaded and installed. But still not showing on Navisworks Manage.
h_eger
Unfortunately, it is not enough to have the OE for Plant 3D 2024 installed. From version Plant 3D 2024 onwards, you also need the OE Plant 3D for Navisworks.
You can download and install it under your Autodesk account.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Ray_K
Thank You again.
djacobsltd
Community Visitor
Community Visitor
I found this very useful thank you h.eger, although it was in a different pathdjacobsltd_0-1683800320468.png
Regards
Lyn
djacobsltd
Community Visitor
Community Visitor
Brilliant 🤔
