Plant 3D Mating Flange
BearsFan
BearsFan
This is specific to creating P&ID in Plant 3D.
Using the P&ID PIP pallete group
I create a primary line segment across the page.
I go to Fittings and add a Flange connection in the middle of the line.
See Image 1.
If I try and insert a mating flange, at red point I get Image 2 and Image 4.  I had like 5 other images trying to insert at different points.  Nothing gets me what I want.
Image 2 seems like the best choice. I insert, it does that nonsense, I then rotate it -90 degrees. But this only works on the vertical application.  The rotation point on a horizontal line makes it so it is best to copy and paste a set of flanges from a vertical run.
Thanks in advance for any help or suggestions.
h_eger
Dear @BearsFan ,
such a function is not supported in Plant 3D P&ID. What is this actually about in the P&ID construction?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
BearsFan
So I wanted to show a flange set.  If I insert a flange in a line to represent a break for removing a motor or other equipment, I like to show both flanges.
Or at the end of a line.  Normally we show a flange. Which works as normal, but sometimes we provide a mating flange.  Again I would like to show that so that it is assembled as such.
I work elsewhere so not an issue anymore, but someone else might have this issue at some point.
I did solve this by making my own block.  Which just inserted a flange set and a break.
DBuzinari
Good solution mate, I'll create a block as well. Spec break and flanged connections for maintenance purposes are something used regularly in the industry, I know that every software needs some sort of customisation but this could have come as standard in the pack. Even trying to connect 2 flanges face to face is impossible
